KugaWestie
Cobra 427 Build
KugaWestie
It's  big thank you time tonight.
Over the last 8 weeks or so @CL290005 has been building me a wiring loom for the car. He has done an absolutely amazing job on it and tonight we strapped it into the chassis. There is still more to do on it dashboard side but it is a massive step forward. It fits like a glove.
We started off at the end of November by laying a rope through the car and taping/ labelling it up with take offs, connections etc.
Chris then took this away and started thinking about the loom. We went through a couple of fuseboxes (BMW Mini and Corsa) before finding one that fitted the needs. I sourced a Vauxhall Corsa C column complete as well as a matching wiper motor and assembly  which I hope to use.
As the weeks have gone by we have got together a few times to lay the loom in the car to check for cable lengths and positions.
So here are a few photos of the loom when being built
And the moment before we started fitting it to the chassis
  • Like 8
Share this post
Link to post
CL290005
Not very photogenic  :cry:
the most important thing is I’m still married and allowed in the house :laugh:
  • Haha 4
Share this post
Link to post
KugaWestie
A few shots of it fitted to the chassis. There is not much to see because of how well it fits and is tucked away. I need to properly fit the fuse box onto the bulkhead.
  • Like 6
Share this post
Link to post
KugaWestie
Whilst Chris was over tonight we also spent a bit of time looking at positioning the Corsa Column, so I now need to make some brackets up for this to try and nail the position
Share this post
Link to post
Thrustyjust
1 minute ago, CL290005 said:
I thought you had been a bit quiet recently Chris.................. it all makes sense now :t-up:
Share this post
Link to post
CL290005
Sworn to secrecy :p
  • Haha 1
Share this post
Link to post
corsechris
I know how much work that involves...you'd best get a bulk order in for the Hobnobs Gary - I think Chris just earned a lifetime supply.
:yes:
Share this post
Link to post
KugaWestie
:yes:
I still cannot believe he offered to do it! I refused the offer at first telling him he was mad. Forever grateful I am
  • Like 3
Share this post
Link to post
BCF
^ this is awesome! Major steps forward!!
Share this post
Link to post
Gary Taylor - Scotland AO
Great work , really neat and tidy and having had to make and sort a few looms appreciate just how much time and effort go into it
Share this post
Link to post
CL290005
What you can see are mostly the sub looms to allow for testing and easy removal of items, once Gary finalises the steering column, heater and wiper motor positions I will then loom wrap those looms and tidy up
Yes building a loom is very time consuming many hours planning, checking every joint is soldered and crimped
Fingers crossed it works as designed in the car
  • Like 4
Share this post
Link to post
Adge Cutler Dorset AO
Blimey, those "in progress" photos of the loom in build give a taste of the time, thought and effort that goes into it. Having not done it, never considered the effort required. Well done. More great progress.
Share this post
Link to post
KugaWestie
Over the last couple of evenings I have been sorting out my throttle cable.
Looking at the bulkhead and servo position, the cable had to go through right in the top corner above the accelerator pedal. So I drilled the hole for it
That was the moment I realised I needed to alter the pedal
Last night I extended the pedal and run the cable through to the engine
I came up with a cable clamp and rigged it up temporarily.
On testing the pedal it felt a bit stiff, so I decided to think about it for a day. When I tried it again tonight I decided it needed to change.
Here is the modification, basically I have raised the pivot point making the pivot lever on the cable side shorter and the pedal side longer. The result is a nice smooth feeling pedal. The pedal bottoms out nicely onto the bulkhead right on WOT as well. So I am glad I persevered.IMG_3586.thumb.JPG.ffd434ecfb2d43e668dd1b2aff6598fe.JPG
Final cable clamp arrangement
Here is some action
  • Like 3
Share this post
Link to post
Impressive to say the least, keep it up :yes:
Share this post
Link to post
KugaWestie
I have started to look at exhaust mounts at the rear of the car. As we know rubber bobbins need to be in compression so I came up with a sketch design.
Having reviewed positions under the car, I decided to utilise some threaded holes on the bottom of the diff that have no use at present.
Its work in progress but I am pleased with how it has come out so far. I intend to modify the design  of the bracket that takes the bobbin and then make one for the other side. The pleasing thing is I have managed to position the mount where the pipes join so can kill two birds with one stone on the mounting/joint.
A view looking up the tunnel from the back of the car
The mount that I intend to improve
The other side side waiting for a mounting bracket
  • Like 5
Share this post
Link to post
