hu7ch
XTR2 diff alignment
hu7ch
Hi Guys
So the XTR is now Taxed & MOT'd, I have a couple of little teething problems but noting too bad,  the only one I'm unsure of is the alignment of the rear diff/sprocket.
It all looks to be inline but as you turn the wheels the chain gets tighter and then loosens off, like its egg shaped, is this something anyone's come across.
I've just read that maybe I should of loosened the grub screws in the bearing carrier, although I'm not sure how this would make a difference.
Any help would be appreciated
Chris
Share this post
Link to post
XTR2Turbo
The rear sprockets are not always cut in half and machined accurately.  You need to adjust chain tension to reflect tightest spot.
Also if you have the standard adjusters get them changed for something stronger.
David
Share this post
Link to post
CraigHew
Going back to my Ducati days, the sprockets tended to be OK with any wear affecting the profile of the teeth and not the roundness of the sprocket. Tighness in the chain always meant one thing, part of the chain had stretched and if you happened to adjust the free play at the loosest point then tight spots occur.
Dont know how old your final drive chain is but I'd treat it as a comsumable and swap it out for the best quality one you can afford..
Share this post
Link to post
hu7ch
Thanks for the replies
so I did finally figure it out and in was in fact the chain had stretched.
@XTR2Turbo I believe they are the original adjusters, where could I get uprated ones from. Do you have any pictures of them
thanks
Share this post
Link to post
XTR2Turbo
I made myself. Will post some pictures next week when back home and in front of the pc
Share this post
Link to post
