M6 WSC
Problems starting engine
M6 WSC
Hi All,
I've got an issue with my Westie that I hope someone can shed some light on.
Recently when I go to start the car, nothing happens... I'll explain.
1. Turn key on
2. Wiggle immobilizer fob next to wire, can hear fuel pumps running
3. Press the start-stop button, and it just makes a 'click' and the starter motor does nothing. (The click seems to come from around the induction side of the duratec)
However, 1 time in 20 or so, it starts fine!
Things I've checked already:
1. Battery - fully charged
2. Starter motor - works fine during the time when it actually starts
3. Fuel pumps - Working
4. Immobiliser - Pretty sure the fob + wire contact is working fine.
5. Same issue whether it's a hot or cold start
Any thoughts?
Many thanks as always,
Rob
Share this post
Link to post
Captain Colonial
Ground wire
Starter solenoid
Bad cell on battery - you can still get a 12.7v reading on a battery with a duff cell.
Suggest trying a jump start to see f it works, then if it does, repeat it several times for proof of concept.  Good luck!
Share this post
Link to post
Terry Everall - WSCC Competition Secretary
When you say the battery is fine what voltage is it to start with and what is it when you turn ignition/starter?
Share this post
Link to post
Thrustyjust
Starter solenoid dicky. Strip it, clean and regrease.
Share this post
Link to post
SootySport
By pass the immobiliser just check it's not that.   Does seem it's the starter or solenoid, battery problem.
Share this post
Link to post
Certainly worth trying a start with jump leads connected to another battery
Share this post
Link to post
M6 WSC
Thanks everyone - willl try that today :)
Share this post
Link to post
Phil J
I had very similar starting problems on my runaround tin top, it turned out that it was as simple as corrosion between the battery terminals and connecting leads. Cleaned the terminals to shiny metal and problem solved.
Share this post
Link to post
