chris parkin
Blacktop alternator/starter motor wiring
chris parkin
Morning all,
its been a while since I took the cables off and I didn't take a picture. Can anyone help with the correct location for both starter and alternator?
Additionally, on the starter motor end, where does the earth from the chassis bolt to? Is it through the bell housing caphead bolt or to the hex head that goes into the block?
Share this post
Link to post
jonjh1964
Eyelet with two brown wires goes to the left most terminal and eyelet with the single brown/yellow to the centre terminal, right most terminal not used (you don't appear to have a nut on it anyway.  My earth cable goes to the bell housing.
Share this post
Link to post
chris parkin
Thank you sir! Much appreciated.
Share this post
Link to post
chris parkin
Can anyone help out with starter motor wiring?
Share this post
Link to post
jonjh1964
Starter wiring looks correct as it is you just need to add the battery positive to the stud with the 3 x thick brown wires.
Share this post
Link to post
chris parkin
Perfect, thanks John, and finally the black (I'm assuming an earth?) on the alternator? Left most cable in the first picture.
Share this post
Link to post
Snappy
Think your sorted now but I always take loads of photos as you say sometimes it's ages before your back in the job, then who knows what goes where?
Share this post
Link to post
chris parkin
Many thanks for the image, what is that unit on the left hand side of the pic? I've just stripped my gearbox and was very thorough with pictures, paid dividends on the way back together!
Share this post
Link to post
darve
Looks like oil pressure sensor to me
Share this post
Link to post
chris parkin
ahhh sweet, so should just be a single cable to the back of the gauge? I can check continuity to the rear of the gauge to make sure its the right one.
Share this post
Link to post
Snappy
Yes its the oil pressure gauge sender....
Share this post
Link to post
