Dave Eastwood (Gadgetman) - Club Secretary 7,792 Posted February 27 Share Posted February 27 It looks like it. The people like me, using pull up resistors are using the stock universal AiM loom that AiM supply with the dashes, I guess, or making their own. Your IVA loom is a special custom loom, that looking at the wiring diagram will have things like resistors, where required, built in, I suspect. Ive not really seen anyone else on here post about having one, I suspect you’ll just have to try it and see. 1 Quote Link to post Share on other sites
Mike424u 85 Posted February 27 Share Posted February 27 55 minutes ago, Chrisn01 said: Hey fellas, Hope your all having a good weekend. Need some help from some of you AiM guru's. So, I'm almost there and got everything on the dash wired in with the exception of the fuel level which has got me a bit confused. Im using the VIL loom Do I simply connect CH1 yellow wire to the loom fuel sender signal wire as am a bit confused as alot of people mention pull up resistors etc and not sure how to go about it using the IVA loom. Cheers guys 23 pin AMP connector as wired for a sport 250 and SCS ECU all from Westfield AIM MXS Strada 1.2 rear connection plugs Sport 250 with SCS ECU CAN PLUG Yellow not used /capped off Black GND To black SCS / loom Blue can 1 To Blue SCS / Loom White can + To Red SCS / Loom Red 15 VDC To WF / Speedo Green USB CAN EXP Aim 23 pin plug which splits 2 ways 1st split has 3 wires Black To Yellow / white stripe WF / Speedo Brown To IGN live Not used with SCS capped off Blue To Earth Not used with SCS capped off 2nd split has 9 wires Red to red WF / Oil temp White / black to purple SCS loom Oil pressure Green /Red to green/red WF / lights indicator LH Blue / white to blue / white WF / Lights Main beam white Green / white to Green / white WF / Lights Indicator RH Blue / Green to Blue / Green WF/ Water temp Green / black to Green / black WF / Fuel level Red / blue to Red / Blue WF / Fog illumination Blue / Red to Blue / Red WF/ Dip beam VGA connector Small loom lock not used. Not used on the SCS loom, Tie out of way Potentiometer not used Not used on the SCS Loom Tie out of the way OBII Connector Min USB Connector, connect to laptop to send configuration file to AIM for set up. 2 Quote Link to post Share on other sites
Chrisn01 236 Posted February 27 Share Posted February 27 43 minutes ago, Dave Eastwood (Gadgetman) - Club Secretary said: It looks like it. The people like me, using pull up resistors are using the stock universal AiM loom that AiM supply with the dashes, I guess, or making their own. Your IVA loom is a special custom loom, that looking at the wiring diagram will have things like resistors, where required, built in, I suspect. Ive not really seen anyone else on here post about having one, I suspect you’ll just have to try it and see. Thanks Dave :0) will try connecting it straight to the signal feed in that case. On RS3, you have the option of either reading Mv or Ohm's with pullup resistor cal. Which one should I go with. Also, when calibrating the fuel, is it just a matter of adding a litre at a time & recording the value with a multimeter with one probe on the dash earth & the other on the signal wire. Then plot the results into RS3. Quote Link to post Share on other sites
Dave Eastwood (Gadgetman) - Club Secretary 7,792 Posted February 27 Share Posted February 27 You shouldn't need the pull up calculations, as I'm guessing it's already built in. Some useful AiM info here: https://www.aimtechnologies.com/sensor-issues/ Fuel sender: Connection https://www.aimtechnologies.com/support/faq/FAQ_Sensors_Fuel_level_100_eng.pdf Configuration https://www.aimtechnologies.com/support/faq/FAQ_RS3_Fuel_level_100_eng.pdf This may help with configuring the alarm leds https://www.aimtechnologies.com/support/faq/FAQ_Sensors_MXSStrada_Alarm_LEDs_100_eng.pdf 1 Quote Link to post Share on other sites
Dave Eastwood (Gadgetman) - Club Secretary 7,792 Posted February 27 Share Posted February 27 If you connect your lap top to the powered up dash, you can see the actual feedback Voltages, as read by the dash. I normally use these for calibration, then it factors out any losses on the wiring/connections. 1 Quote Link to post Share on other sites
Steve (sdh2903) 3,534 Posted February 27 Author Share Posted February 27 4 minutes ago, Dave Eastwood (Gadgetman) - Club Secretary said: If you connect your lap top to the powered up dash, you can see the actual feedback Voltages, as read by the dash. I normally use these for calibration, then it factors out any losses on the wiring/connections. Yep very useful that live page. 1 Quote Link to post Share on other sites
Dave Eastwood (Gadgetman) - Club Secretary 7,792 Posted February 27 Share Posted February 27 1 minute ago, Steve (sdh2903) said: Yep very useful that live page. Hugely, plus, you can manually enter Voltages, too, for as yet unconnected senders, so that you can test the programmed logic of your warning lights, triggers etc works as you intend. The live test page is your best friend when it comes to set up testing and configuration. 1 Quote Link to post Share on other sites
Simon Waterfall Syman84 711 Posted February 28 Share Posted February 28 Been a while but, progress. I need to swap some settings in race studio but light at the end of the tunnel It's alive 1 Quote Link to post Share on other sites
Simon Waterfall Syman84 711 Posted April 8 Share Posted April 8 ok so got the wheel speed sensor fitted up last night but no joy on reading speed, looked in RS3 just and my setting were all over the place. does the below look ok now for a 4 pulse on the front wheel using the hub bolt heads for the signal. will hopefully be able to try it out later thanks Quote Link to post Share on other sites
Chris King 5,024 Posted April 8 Share Posted April 8 I had loads of hassle getting this to work - even tried 3 different sensors. Turned out that the pin in the amp connector plug wasn’t quite pushed in all the way! Worth checking. I’ll look at my settings later for you 1 Quote Link to post Share on other sites
Adge Cutler- Dorset AO 1,619 Posted April 8 Share Posted April 8 Similar to mine if it’s any help: 1 Quote Link to post Share on other sites
Mike424u 85 Posted April 8 Share Posted April 8 to mine, but not sure HZ and you need to be sure on wheel circumference Quote Link to post Share on other sites
Steve (sdh2903) 3,534 Posted April 8 Author Share Posted April 8 4 hours ago, Chris King said: I had loads of hassle getting this to work - even tried 3 different sensors. Turned out that the pin in the amp connector plug wasn’t quite pushed in all the way! I've done this aswell 😳 The pins aren't the easiest to push fully home. Are you using the dedicated speed sensor input? Or an analogue channel? Quote Link to post Share on other sites
Dave Eastwood (Gadgetman) - Club Secretary 7,792 Posted April 8 Share Posted April 8 And re the Hz, this is the sampling frequency, ie how often, per second, speed is being read by the dash, for a speed readout it doesn’t need to be spectacularly high - that’s just tying up system resources. Its always worth setting the sampling rates to be as few as possible, for each individual input, so speed, 20hz should be absolutely fine, an even slightly slower rate would probably look OK, too. However for something like oil pressure, where you want to know the instant any sudden change happens, then keep it at 100hz. Alternatively, sometimes, when you’re logging and analysing inputs later, like say suspension travel and steering wheel movement, you may want to have quite high sample rates at times, to capture very brief issues on the data logs. Quote Link to post Share on other sites
Chris King 5,024 Posted April 8 Share Posted April 8 58 minutes ago, Dave Eastwood (Gadgetman) - Club Secretary said: the data logs Can you access these Dave? Quote Link to post Share on other sites
