Steve (sdh2903)
Aim mxs info thread
Chris King - Webmaster
Of course, diodes. Now where did I put that pack of 10 I bought 18 months ago?
Share this post
Link to post
4 minutes ago, sdh2903 said:
No. I just earthed the main earth wire. Then used the analogue gnds for any sensors that needed it.
It's the analogue gnds I'm curious about. There's 4x analogues but no indication as to which gnds go with which?
edit: so why not just ground the sensor - or is there a reason to use the dash gnd?
Share this post
Link to post
Steve (sdh2903)
Doesn't matter. They all link together anyway then earth through the earth wire in the other plug.
Share this post
Link to post
I've got to get the car running this weekend as mapper booked next Thursday, but after that will get back on the case with the custom config files.
Share this post
Link to post
Yeah, that's what I thought, just wondered why so many earths were available when you have a whole chassis to tap into :)
Share this post
Link to post
Steve (sdh2903)
When talking to Luke, or it might have been mark at the factory, he did advise to use the analogue earths at the dash rather than earth locally for any analogue sensors.
Share this post
Link to post
Deanspoors
This has been mentioned before with the RT dash, if you use a chassis ground on a sensor, the values change slightly when engine is running/headlights turned on, etc. using an earth directly from the dash minimizes the amount of error.
Share this post
Link to post
Ok thanks for the info will do as suggested :t-up:
Share this post
Link to post
Right then
I'm in Race Studio - so where's the info/instructions on how to add in the fuel level sender?
Do I add a custom sender - if so, what next? No idea what I'm doing here (and I'm a programmer!)
AHA! - found a video tutorial on AIM site - on the case!
EDIT2: not really very useful
Share this post
Link to post
Steve (sdh2903)
If you don't get sorted I can talk you through it. Have a lot of experience with the fuel sender:rolleyes:
Share this post
Link to post
Ooooh yes please mate!
Share this post
Link to post
On the "info line" the dash always says "no GPS" (or similar) - well, yes, I know I have no GPS, any way to change this in Race Studio?
I can't un-tick the GPS options in 'channels', so not sure what else to try - unless I'm missing something obvious?
If not I'll just hack the config files I guess.
Share this post
Link to post
Oh - found this useful calculator for the fuel sender settings.
If you put 5V input and 2700 Ohm R1 for your voltage and pull-up settings, then use the quoted 10 & 180 Ohm values for empty and full for the VDO sender, you get 18mV and 313mV - which is close to your values @sdh2903
Of course this assumes your sender is set up to actually output those values - best to measure.
Share this post
Link to post
Steve (sdh2903)
I've emailed aim twice now about this with no reply as yet. I don't see why you can't just turn it off.
Share this post
Link to post
Thought I'd try the fuel sender setup without ripping apart the tunnel top (again) and feeding a direct earth in to the dash.
Using the standard harness feed and earth resulted in a reading that was around 25 litres higher with the engine running.
So then I tried earthing direct to the chassis.
Result!
Shows the same reading regardless of engine running or not.
Now I just need to calibrate it properly but pleased that I didn't have to rewire anything more as I've just about had my fill of wiring!
But, my speedometer sender isn't working. Not that I expected it to mind as it's a £5 Halfords cycle computer magnetic one :d
Time to find a Hall effect job, but for now I'll use my Garmin as a trip and speedo.
Speaking of trip, how do you reset the one on the dash (without resorting to Race Studio)?
Share this post
Link to post
