Tpacker 0 Posted January 29, 2017 Share Posted January 29, 2017 Hi has any body ever installed a GI pro gear indicator onto a Megabusa? Is it easy? Do you have to cut any wires? thanks Tom Quote Link to post Share on other sites
XTR2Turbo 635 Posted January 29, 2017 Share Posted January 29, 2017 I would buy the geartronics one as it uses the existing bike gear potentiometer rather than calculating your gear from revs and speed. The plug is a white triangular 3 pin connector on the bike loom already 1 Quote Link to post Share on other sites
gee_fin 366 Posted January 30, 2017 Share Posted January 30, 2017 I used (and have for sale) the GiPro speedo one, really easy to install and program and neat little unit - this is the one that picks up from the speedo and rpm (so works on any car, any box) not the one that works from the gear signal. Was quite impressed with the unit. Only changed as went to digital dash. Quote Link to post Share on other sites
CosKev 1,054 Posted January 30, 2017 Share Posted January 30, 2017 As above in my experience I would go for one that uses the bike gear indicator switch if the bike had one as standard. I've used and seen on other cars the ones that use speed and revs can get lost/confused if you say downshift more than one gear at once without letting the clutch out. They then don't show a gear until you have had the clutch out for a while with the car moving and it's worked out what gear you are in. Quote Link to post Share on other sites
Beez 19 Posted January 30, 2017 Share Posted January 30, 2017 I've got the geartronics one too, never had any problems with wrong gears showing up etc. And was really easy to install Quote Link to post Share on other sites
Tpacker 0 Posted January 30, 2017 Author Share Posted January 30, 2017 Thanks all, is the geartronics one literally a plug and play and does anyone no where I would connect it into the hayabusa loom? Hoping it is literally just a plug as not really confident in cutting wires etc. Quote Link to post Share on other sites
XTR2Turbo 635 Posted January 30, 2017 Share Posted January 30, 2017 as per above there is a white triangular 3 pin connector on the bike loom. It comes out near the stator. Quote Link to post Share on other sites
S2T 85 Posted February 20, 2017 Share Posted February 20, 2017 On 30/01/2017 at 18:59, Tpacker said: Thanks all, is the geartronics one literally a plug and play and does anyone no where I would connect it into the hayabusa loom? Hoping it is literally just a plug as not really confident in cutting wires etc. Tom What did you buy at the end of the day and have you fitted it? Steve Quote Link to post Share on other sites
Tpacker 0 Posted February 21, 2017 Author Share Posted February 21, 2017 Hi, I haven't got round to ityet but defiantly be buying one next month. Quote Link to post Share on other sites
