robhume 213 Posted September 13, 2020 Author Share Posted September 13, 2020 New Edge alternator and mounting bracket fitted. Thermostat housing replaced with non cap type and new fan switch so cuts in around 80c. White smoke gone not a clue what that was about. Coil pack and 3 bar map sensor fitted on ally panel above foot well. New crank sensor fitted and all running ok. Don't know whether to keep it or sell it. 5 Quote Link to post Share on other sites
andyj007 99 Posted September 14, 2020 Share Posted September 14, 2020 looking good rob.. sent you a pm m8 Quote Link to post Share on other sites
TwinCam 20V 0 Posted September 30, 2020 Share Posted September 30, 2020 I like the ITB´s Quote Link to post Share on other sites
robhume 213 Posted October 1, 2020 Author Share Posted October 1, 2020 TwinCam20v, perhaps not clear in the photograph but they are Weber carbs. Quote Link to post Share on other sites
Stromnery9 0 Posted October 10, 2020 Share Posted October 10, 2020 Nice buddy Quote Link to post Share on other sites
robhume 213 Posted October 14, 2020 Author Share Posted October 14, 2020 Just found a couple of small cracks at the top of the windshield about 8mm long and thinking of drilling a tiny hole at the bottom of each to stop more travel. Then a small amount of silicone into the holes. Anyone got any experience of this type of problem. Quote Link to post Share on other sites
stephenh 940 Posted October 14, 2020 Share Posted October 14, 2020 I don't have experience of the problem, but I think your method of dealing with it is on the right lines. In terms of how to fill the resulting little holes, you might consider using a windscreen repair kit, such as RainX. I've actually got some, but never used it so can't give first hand experience of how easy or effective it is. Maybe someone on the boardroom has used it? Quote Link to post Share on other sites
robhume 213 Posted October 14, 2020 Author Share Posted October 14, 2020 Thanks Stephen, Unfortunately this happened when the car was away having some work done on it but I discovered it too late. Previously I have used dichloromethane but for perspex and not sure if the screen is perspex or something else. I'll look into your suggestion. Quote Link to post Share on other sites
jonjh1964 723 Posted October 14, 2020 Share Posted October 14, 2020 Rob, I’ve had numerous problems with the screens developing cracks/crazing along the edges, especially during really hot weather. I think it’s a combination of the Perspex being stressed to fit the car and not being fully de-stressed as part of the manufacturing process. I’m now on my 3rd screen and, even though the new one has only been out of the garage once, it already has some very light crazing. Be very careful what products you use to clean/polish, for example the standard RainX is not compatible with Perspex and you need a ‘plastic’ variant if you want to use it. Jon Quote Link to post Share on other sites
robhume 213 Posted October 14, 2020 Author Share Posted October 14, 2020 Hi Jon, thanks for the info. Being a tight jock, I use water but, chemical free, I'm not sure. The screen does need careful handling though, so I try and bear that in mind. 1 Quote Link to post Share on other sites
jack46606 0 Posted November 20, 2020 Share Posted November 20, 2020 Unfortunately, no progress at the moment, I thought I was still 21 and lifted a zx10r engine. Silly boy, my back is causing me really bad pain. Will I ever learn, probably not. 1 2 Quote Link to post Share on other sites
