Building my Eleven
robhume
 Share
+1 on using a cross flow. Either that or a huyabusa, not much else will fit without a bulge... I had to use a period engine for class regs , so put a 1600 xflow in mine. Using the World Cup engine mounts (I got from burtons) makes fitting the cross flow really easy. (And easy to do Engine swaps too)Really the only clearance issues is the rocker cover filler which you must move to the rear - but remember to baffle it really well..Trust me... bad things happen otherwise. I actually sealed mine  with a cap and ran a separate breather, after a spectacular oil leak at high G right hand cornering...(see pic of the cap I made which slides into the relocated filler)
With twin webers, the manifold likely will need to be remachined to change the angle of the carbs a tad. The front fuel banjo and carb cap is still very close to the hood in any event. You’ll then need the side entry dizzy cap too. Speaking of bad things happening, and poor location of distributors..talk to your Weber expert about sealing the choke vents if you’re racing ... both elevens here have spontaneously combusted due to racing conditions and the inherent  dcoe design where high g causes fuel to exit the carbs... and guess where that goes...
As for sumps, the beauty with no cross member, you can make a shallow full length  winged baffled wet sump, with flappers etc and still hold 5 litres.  On 13” rims  and Avon  acb10’s I  had 50mm ground  clearance at full droop, for racetracks this was fine ... but I still had a bash plate under it just in case of excursions .  I race my car and have had no surge issues at all with the wet sump I made.  Dry sump will gain you another 40mm  and the ring gear will likely then be the impact point. All lessons hard learned... EBEB46C0-3967-48B3-B16F-6B090D3FB547.jpeg.498d7bde78fcf2941ded00e34a420148.jpeg
Link to comment
Love your oil cap solution!
What a good idea on the engine mounts, too.
Link to comment
  • 3 months later...
Eventually managed to get some time to trial fit the crossflow engine prior to making the engine mounts.
At the moment it is on the engine crane with some wood blocks under until I get the bonnet clearance set.DSC_0432.thumb.JPG.04c792c6687ccb50d1083923f2d5bec2.JPGDSC_0434.thumb.JPG.c8a927d2616c1de3ec88e4ebb21a5feb.JPG
  • Like 3
Link to comment
Morris, I just thought I would add that I looked at the clearance under the chassis tubes and the bottom of the sump
is below the bottom of the chassis tube by  1/4". The sump, (wet) is what came with Mr T's engine and is 5" from
under the block to the bottom of the sump.  Looks to be a modified crossflow sump, 1600cc type for crank throw clearance.
Once I offer up the bonnet I will be able to see what clearance there is but, the only item I can see that may pose a problem
is the thermostat housing, so may have to mod that a bit.
Out of interest, the dry sump pan I have measures 5" as well, so no benefit to be had size wise, but lubrication we will
have to see.
Link to comment
Thank you Rob.
Looks like you have plenty of experience in adapting engines to make them fit by understanding what mods work without causing detrimental consequences.
I've clearly a lot to learn in that department and will have to stick to keeping installations basic for a while!
Link to comment
  • 2 months later...
After a lot of faffing about with the engine crane and blocks of wood, the engine is finally in place and the mountings done.
The idea is similar to that used by Redescape. The aluminium panels on the bottom chassis rails will need a bit of tidying.
There is clearance for the bonnet, even using the thermostat housing with the cap.
The next job is to slightly modify the lower pipe on the manifold, then mate to the existing exhaust system.
I decided to use the Motorsport Electronics Nodiz ignition management with a coil pack and also a 3 bar map sensor as the
carb inlets already had tappings and using the Zetec plug and play loom with some flying lead connections should make it
fairly straight forward.
Link to comment
Damn, I should have done that too, beside relocating the crossflow lower on my lowline narrow body...
Link to comment
  • 5 weeks later...
Progress has been a bit slow on the crossflow install but I have
now managed to fit the cooling hoses, fuel pump, regulator and
modify the accelerator cable to suit the Webers.
The exhaust will need a bit of alteration after the collector box but
not too difficult.
The jobs left to do are; find a home for the ECU and coil pack and,
a very small amount of wiring and hope the whole thing works.
  • Like 5
Link to comment
  • 1 year later...
After what seems like ages, the car has gone off today to have the carbs set up and
connect  the Nodiz. It's amazing how small the car is without the bodywork and the
engine fits nicely under the bonnet.
  • Like 6
Link to comment
  • 2 weeks later...
Out of interest, what was the reason for swapping to a X/Flow from the Zetec?
Link to comment
I go over to France for some hill climbs John, mainly Normandy and, now with the Crossflow engine and the Midget running gear in the car,
I will be able to  just squeeze into the later "historic" class despite the chassis being newer.
Link to comment
Thanks Andy, not yet, it's being done as an infill job and there is a small problem in that
the alternator is charging at 17volts at tickover. Once that is sorted, it will be ready for
the rollers.
Link to comment
  • 2 weeks later...
Unfortunately the overcharging problem with the alternator is still not solved despite doing various tests and a new alternator.
And to make matters worse, the engine is puffing out clouds of white smoke, probably a head gasket, bit miffed about that..
So decided the car will come back and hopefully sort the problems myself but at least the ST loco R1 is performing as it should,
mighty fast.
  • Sad 1
Link to comment
 Share
