robhume
Building my Eleven
John
3 hours ago, robhume said:
I've already been told it would as it is classed as an electronic aid.
Ah OK. I didn't realise
Share this post
Link to post
robhume
I'm having small problems with the spring loaded bolts that serve as door catches on the Eleven.
It would appear that the bolt is not going far enough into the hole in the GRP and is resulting in
the door opening.
The main problem is that there appears to be not enough space to get an open ended, normal
thickness spanner in to slacken the nuts which may allow the bolt to be moved slightly so it
engages the hole more positively.
I have been looking for "thin" open ended spanners that may suit but with no success yet and
was wondering if these are available or what the factory uses to fit the bolts in the first place.
Share this post
Link to post
stephenh
Long nosed pliers?
Share this post
Link to post
robhume
Tried long nose pliers Stephen but still could not do it. However I have found some 3mm thick
open spanners, so hopefully they may do.
Share this post
Link to post
jonjh1964
Rob,
My lock has captured nuts welded to the spring loaded bolt mounts. The whole mechanism is adjusted by adding washers between the GRP inner door or elongating the holes to adjust the position.
I had a problem fitting a ‘stack’ of washers and eventually glued them in place with a hot glue gun.
Jon
Share this post
Link to post
robhume
Hi Jon,
The problem is, the nuts on mine are not welded to the mount and just keep turning.
So I will have to remove the spring loaded bolts and weld on some nuts and elongate the
holes on the door to give a little adjustment.
When I used the car last August at the hill climb, I had to secure both doors with
a couple of bungees. Not very high tech but did the job.
  • Haha 1
Share this post
Link to post
John
Could you make a spanner from a piece of sheet steel?
Share this post
Link to post
Simon Marks - North Oxfordshire AO
Hi, Rob,
I've been away from the computer all weekend so rather late to this thread.  So far, I'd be with John and make up a spanner from a strip of steel.
A couple of "off the wall" suggestions - why not drill and tap the end of the bolt and then threadlock a setscrew in the end to extend the "throw" whilst leaving the mechanism in the same place.  Alternatively, is there clearance to allow for the fitment of an escutcheon on the door jamb?
Simon
Share this post
Link to post
robhume
It would be very possible to make a spanner from flat sheet.
One of the nuts is relatively easy to get to but the one nearest the door end is extremely tight for space.
There is probably enough space to fit an escutcheon on the jamb but the nuts and bolts on both doors need
tightening, so I will have to devise a way of doing it.
In the same class as me last year was a Crossle sports racer and he was using spring bonnet catches
to keep the doors closed which actually worked much better than my bungees.
Share this post
Link to post
paul kynaston
Bicycle spanner ,they are usually made from flat sheet and thin.
Share this post
Link to post
robhume
Ah, good suggestion, had forgotten about them
Share this post
Link to post
robhume
Hopefully the cooling problem has been solved,
I have added a filler neck with an 8mm spigot outlet with a hose going to an vented overflow bottle
with a tube going to the bottom in a small amount of coolant.
The fan cuts in at 95 and goes off at about 82.
I have also added a bit of ducting to direct the airflow to the rad, which is still the Midget one.
Hopefully I will actually get the car out for Hethel.DSC_0348.thumb.JPG.d536adfd055446b59bbbf7365ae55ea5.JPGDSC_0347.thumb.JPG.960370540b189aaf7ede2a2facb0301e.JPG
  • Like 4
Share this post
Link to post
robhume
At long last we are doing a sprint. Car loading for the Lotus test track at Hethel.
Apart from the trip to France last year for a hill climb, it's been two years since I last did a sprint,
so back to the beginning for me.DSC_0365.thumb.JPG.7477d3cb77fc52bc14680291f3fde21f.JPG
  • Like 3
Share this post
Link to post
stephenh
Good luck Rob, I hope it runs well for you.:t-up:
Share this post
Link to post
robhume
Thanks Stephen, I hope it all holds together, especially me, age is a wonderful thing but not when you get older.
Share this post
Link to post
