robhume
Building my Eleven
robhume
Part of the mods to be carried out will include the setting up of this load cell gear lever knob.
This senses two directional movements and is suitable for H pattern dog boxes.
It will be linked to the ecu to trigger and ignition cut which will allow flat shifting.
Not as good as a sequential 'box but still keeps the car in the appropriate class.
Share this post
Link to post
Terry Everall - WSCC Competition Secretary
That looks a great idea Rob
Share this post
Link to post
robhume
Cheers Terry, it took a bit of investigating and will need some setting up but should be fun, even on an Eleven.
Share this post
Link to post
Nick - Joint North East AO
Cracking idea Rob :yes:
Share this post
Link to post
robhume
Newman cams fitted, part of the upgrade, hopefully adding a bit more oomph.
  • Like 4
Share this post
Link to post
robhume
Car is now back with cams fitted, revised and simplified cooling system and the load cell configured.
Unfortunately I don't seem to be able to upload the dyno run, quality was not too good anyway.
Now I need to refit the bodywork and tidy a few areas prior to getting a vehicle passport, it all takes time.
And then there is the grass, which persists in growing.
(The offside splash guard needs trimming as it is compressing the air filter)
Share this post
Link to post
W3ster
Any new updates on this build?
Share this post
Link to post
robhume
W3ster, not sure what you are asking about specifically.
If there is something you want to ask, please do and I will
try to answer.
Photograph is of the car in the paddock at Etretat last August with it literally, starting, steering and well, sort of stopping,
so really now, it's checking over and changing anything that needs it and carrying out some upgrades.
Share this post
Link to post
robhume
Latest photograph and very little left to do but no doubt I'll find something
Share this post
Link to post
John
Where did you get the load cell Rob? Car is looking great
Share this post
Link to post
robhume
Hi John,  it's KA sensor product supplied by EPS Motorsport, I guess it's EPSmotorsport.com
Share this post
Link to post
John
Thanks. Does it work OK?
Share this post
Link to post
robhume
Yes it's ok so far, provided I don't play with the knob, sorry is that a bit rude.
I believe, depending on the force applied to the lever, the voltage changes and activates an ignition cut via
the ECU. All I know is it works, even across the gate but of course has to be on a dog box.
Not quite as fast as a sequential box but a lot less expensive.
From the speed series point of view, it will put me in a different class mentioned before anyone gets upset.
Share this post
Link to post
John
Thanks. I'm not sure it would put you in a different class. only H pattern and sequential are separated at present
Share this post
Link to post
robhume
I've already been told it would as it is classed as an electronic aid.
Share this post
Link to post
