crank sensor for 2 litre XE (redtop)
Anybody got a good one or know of where to buy?
they are cheap of eBay about £25. genuine ones will be over £100   .
I had trouble last year with after market ones but only because of my flywheel was a special . you should be ok if using in the std position
I'll have one spare soon as I'm going to external sensor, will be 6-8 weeks away though...
if anyone has genuine Vauxhall one in good condition I would like one too
the last one i bought was from Andrew page parts £23. its been on at least 8 years
http://www.andrewpage.com/
I've got two, both will be spare once the dry sump kit is on :t-up: but you'll have to wait!
Just replaced a failed Bosch unit with a plastic alternative, £25 off ebay. Works fine.
  • 3 weeks later...
Plastic one I bought does not work
They are £96 from SBD
Anyone know the part number
I have an old one that says 0281210 on it but when I search it comes up as a SAAB part
Don't forget that Saab and Vauxhall are (or were) both parts of the same company, Tel, so could well be correct?
I have a new set of front hub bearings and spacers for a Midget Mk III, but the box says they are for a Morris!
I would have thought John Hoyle would be your man
I have a spare in my toolbox but it's for a 1.6, although I think they are the same - will post a photo tomorrow.
This any good to anyone:
can you found the same but cheaper Bernie :d
