Chris King 4,799 Posted June 23, 2015 Share Posted June 23, 2015 So any ideas why my front brake squeals like a banshee on heat? I've tried copaslip on the back and sides of the pads taking care not to contaminate the disc or pads. Worth cleaning the discs? Quote Link to post Share on other sites
Stu Faulkner 1,827 Posted June 23, 2015 Share Posted June 23, 2015 Get them warm and then slam the anchors on at about 120MPH. That sorts them out. Seriously though they will settle down as they bed in. Good to se you on the road Chris, Stoneleigh next year? Quote Link to post Share on other sites
Chris King 4,799 Posted June 23, 2015 Author Share Posted June 23, 2015 Get them warm and then slam the anchors on at about 120MPH. That sorts them out. Seriously though they will settle down as they bed in. Good to se you on the road Chris, Stoneleigh next year? I'll pop out and try that then Stoneleigh? Hell yes! Quote Link to post Share on other sites
SootySport 1,038 Posted June 23, 2015 Share Posted June 23, 2015 Depends what pads you have. Track pads always squeal when cold, road pads should be ok from the go. Quote Link to post Share on other sites
Chris King 4,799 Posted June 23, 2015 Author Share Posted June 23, 2015 Mintex 1144. A good blast has improved things. Still squeal but not as much. My first proper blat and grinning like a kid! These thing dunnarf shift like 2 Quote Link to post Share on other sites
CosKev 1,028 Posted June 23, 2015 Share Posted June 23, 2015 So pleased for you after the worries of DVLA Do the Willwoods run any type of metal shim between pad and caliper? Quote Link to post Share on other sites
Chris King 4,799 Posted June 23, 2015 Author Share Posted June 23, 2015 Do the Willwoods run any type of metal shim between pad and caliper? Nope. Quote Link to post Share on other sites
tisme 239 Posted June 23, 2015 Share Posted June 23, 2015 I've just changed to Mintex M1144's on my Wilwood Midilites and they're the first pads I've had that squeal !! Not a lot mind you and only for light braking - but the stopping power and feel is soooooooooooooo much better I can live with it. The Midilites have stainless steel pads retainers (that put pressure on the edge of the pads) and are supposed to be a "Squeal Reduction System" so assume the noise would be worse without them Quote Link to post Share on other sites
Ian Tolfree (tolf) - WSCC AO Rep 572 Posted June 23, 2015 Share Posted June 23, 2015 Have you got the caliber spring seated right, so it pushes the pads away from the disk? Quote Link to post Share on other sites
Chris King 4,799 Posted June 23, 2015 Author Share Posted June 23, 2015 Have you got the caliber spring seated right, so it pushes the pads away from the disk?Not sure it has one on the powerlites? But will check.*edited calliper name Quote Link to post Share on other sites
Chris King 4,799 Posted June 23, 2015 Author Share Posted June 23, 2015 Helmet made a difference so will try earplugs as well next time. Saves taking the wheels of again Quote Link to post Share on other sites
SootySport 1,038 Posted June 23, 2015 Share Posted June 23, 2015 Mintex 1144. A good blast has improved things. Still squeal but not as much. My first proper blat and grinning like a kid! These thing dunnarf shift like Track pads then, yes they are going to squeal when cold, you're going to have to live it. Brake grease, copperslip and shims may help a bit, but I won't get rid of the noise 100%. Quote Link to post Share on other sites
Greenstreak-Andy D 578 Posted June 23, 2015 Share Posted June 23, 2015 My old Westie had willwood 4 pot, the only pad not to squeal under light braking was the rubbish smart pad. Anything more focused, Mintex or poly A always squealed! Now run with AP setup, no squealing ! Much better forme! Quote Link to post Share on other sites
Pistol Pete 331 Posted June 24, 2015 Share Posted June 24, 2015 Ebc greenstuff pads dont squeel. Quote Link to post Share on other sites
CosKev 1,028 Posted June 24, 2015 Share Posted June 24, 2015 Nope. Anti squeal shims do what they say on the tin But as above, track/race pads are never totally quiet. Quote Link to post Share on other sites
