Sign in to follow this
cast iron
Viscous Diff - Gear oil
cast iron
Am I right in believing the viscous coupling in the Sierra cosworth syle LSD is a sealed unit with its own oil, within the CWP? And on that assumption you can use any type of "normal" gear oil in the diff housing?
Share this post
Link to post
DanDud
yes that's right
Share this post
Link to post
Terry Everall - WSCC Competition Secretary
Yup!
Share this post
Link to post
CosKev
GL5 oil is all that's needed
Share this post
Link to post
cast iron
cheers folks - new diff with new ratio built, will get some 75W90 for it
Share this post
Link to post
SootySport
So how do you change the oil within the LSD?  I would have thought that 30 year old oil should have been changed by now.
Share this post
Link to post
Dave Eastwood (Gadgetman) - Club Secretary
A few companies, like Bara Motorsport are able to rebuild/refill the viscous module - it uses a silicon based fluid IIRC, at the same time, they can adjust the "settings" at which it starts to lock. How effective a change this is, in a Westfield, I'm afraid I don't know, I've never tried it.
Share this post
Link to post
stephenh
yes, the fluid in the lsd unit isn't an oil at all, it is silicone. And it isn't very fluid either, if you have a jug of it half full you can tip up the jug and it wont run out, at least it will only do so very slowly if you left it tipped up. It is similar product to Katie Price's boobs!
Bara alters the torque transfer effect of the lsd by altering the amount of silicone in the sealed unit and altering the number of little plates in there. Bara earns his money by knowing how many plates and how much silicone and what grade of silicone to use for a given intended use of the diff.  ;)  ;)  ;)
Share this post
Link to post
SootySport
I like Stephens description the best, thanks :yes:
Share this post
Link to post
cast iron
Just off to Google Katie Prices Boobs, purely for technical reasons of course
Share this post
Link to post
