LED indicators
Tim Essex
 Share
I wonder if someone could help me. I'm fitting new LED indicators to my 2008 SEiW, leaving the rest as standard. I need to replace the existing relay as they are flashing too fast but for the life of me I can't find where the existing relay is. The chap I bought it from followed the build plans religiously so I suspect it's in the 'usual' place. Can anyone give me a clue where that is? Photos would help this 'novice but happy to have a go' member. Also would any LED indicator relay work or do I have to get one that works for LED and non LED. Thanks for your help
Link to comment
Hi Tim,mine is an 09 the relays are under the dash on the left hand side,mine is held up by a couple of screws.i would send some pics but I don't know how to to.also I do remember having to change the relay but can't remember where I got it from possibly CBS (car builders solutions)
Link to comment
Tucked up behind the dash. Put your indicators on and trace the noise
And you'll feel it switch, too. Possibly orange
Link to comment
Something like ebay 350801749725 should work, just check the pins are the same layout or you may need to move them in the socket (small screwdriver needed). 150w will be plenty.
Link to comment
 Share
