Fuse box location (now my build thread!)
Ben-H
 Share
After seeing Gary's header tank upgrade, I couldn't resist. So I got one, and a battery tray from Alloy Racing Fabrications. This now allows the bypass by the thermostat housing to return to the header tank, meaning that I've got a small amount of flow while the thermostat is closed.
At the same time I used one of their fantastic, lay flat, battery trays.
While I was at it, I've never been happy with the fuse box location on the scuttle. It leaves the wires showing, I like to keep things looking uncluttered so I've cut a aperture in the panel and sat it down in with rivnuts to bolt it down. Plenty of space between the gearbox and wiring underneath. Quite pleased with the look I think...
Link to comment
Nice Mark. I like the carbon, something for a future upgrade... :)
Is that the standard pedal cover under the carbon? How did you fit it? Did you cut off the upstand that goes up the scuttle, or did you tuck it up behind the scuttle?
Link to comment
The pedal cover is the standard Westfield part. I trimmed it so that there was a 10mm flange left all round the edge and then bonded it to the scuttle with silicone.
Link to comment
Looks good Ben, nice job.
I am glad I am spending other peoples money as well as mine :)
Link to comment
  • 2 weeks later...
I know I'm nearly there, and I'm ashamed to say that I didn't do a build thread at the time as I wasn't here :( but as I've been doing more recently, I'll turn this thread into my build progress. I've got pictures from the start including the Mazda strip out if you guys are interested? If not I'll carry on from where I'm at now.
Link to comment
Made a bracket for the upper steering column today for a few reasons. Firstly it enables me to get the column forward about 40mm so the lower column reaches the rack, but it also puts the wheel in a more comfortable position for my long arms. Secondly it allows me to rotate the column so the ignition key is easier to get into the barrel.
I made up the aluminium plate from stock, the stainless u bolt was a marine item that was a few mm small so it had to be heated up and reformed over an impact socket of the right diameter ;)
Link to comment
Have you used lock nuts on the column bracket? If not, you should
Link to comment
As I am starting my build soon I would like to see how you got on from start to finish. Would probably take a fair while to write up though  :)
Link to comment
Have a look at my build thread - plenty of information in there
http://forum.wscc.co.uk/forum/index.php/topic/90534-kugawesties-mx5-sdv-build-thread-now-an-upgrade-thread/
Link to comment
 Share
