tolf Posted October 12, 2020 Share Posted October 12, 2020 1 hour ago, TwinCam 20V said: Hello Last question ... I can use my stock shocks with the rallydesign wide track kit, right?!?! Yes you can. I have done this, no issues Quote Link to comment Share on other sites More sharing options...
TwinCam 20V Posted October 13, 2020 Share Posted October 13, 2020 Thank you! Quote Link to comment Share on other sites More sharing options...
Jimbohuc Posted May 14, 2021 Share Posted May 14, 2021 How much wider is the wide track? Quote Link to comment Share on other sites More sharing options...
Kingster Posted May 14, 2021 Share Posted May 14, 2021 50mm per side for Westfield - assuming you are coming from “standard” (ie not an SDV) Siltech can do other widths I believe. Quote Link to comment Share on other sites More sharing options...
Jimbohuc Posted May 14, 2021 Share Posted May 14, 2021 33 minutes ago, Chris King said: 50mm per side for Westfield - assuming you are coming from “standard” (ie not an SDV) Siltech can do other widths I believe. Thanks Chris, that’s great. I think going to wide track will solve my trailer runner width issue and I want to change shocks anyway so hopefully win-win Quote Link to comment Share on other sites More sharing options...
Steve20 Posted May 17, 2021 Share Posted May 17, 2021 My Siltech Superwide is plus 60mm per side giving a front track of 1600mm and rear of 1620mm. Quote Link to comment Share on other sites More sharing options...
Dave Eastwood (Gadgetman) - Club Chairman Posted May 17, 2021 Share Posted May 17, 2021 As you can see above, there is no standard dictating what wide track should be. Different manufactures have their own take on it, and even Westfield have done different variations over the years! (So in other words, if the measurement will be critical for you, then measuring your own set up is the only definitive answer, if you're already on wide track, and if it's just a case of future planning, then you'd need to confirm with the manufacturer you planned on using.) Quote Link to comment Share on other sites More sharing options...
