TYRE PRESSURES
Arthur
We never put tyre pressures down in the wet . Cold tyre pressure for wet running always goes up.
Link to comment
Is that to ensure that the 'hot' pressures are about the same for dry and wet conditions i.e. the tyre pressures will increase more in the dry than the wet?
Link to comment
  • 4 years later...
For a new owner...can anyone advise suitable tyre pressures for TOYO PROXES R888 205/50 ZR15. For fast (ish) road use...Many thanks👍
Link to comment
10 minutes ago, evosteve said:
Most run 18 to 20 PSI.
Many thanks, I thought it would be about that. 👍
Link to comment
REMEMBER PRESSURES AREN'T CHECK N' FORGET.
Regularly check them as they change significantly with high weather temps and hard driving and visa versa!
Link to comment
Thanks, yes that is so true. If I have learnt nothing else over my 50 years of driving, it is that tyres are your only contact with the ground and should be checked regularly...especially on performance cars. When I had my 911 I was neurotic about the tyres...what with the engine being slung out behind the back axle.
Very tail happy. 😮😁
Link to comment
  • 2 months later...
On 14/07/2014 at 12:41, dhutch said:
I tend to run 18 front, 16 rear for the road and autotesting in the dry , sometimes lower for autotesting in the wet or on grass, or higher if I want less grip...
18/16 ish seems to give even wear over the width of the tyre, which rightly or wrongly I think  is as good a indication as any along side it feeling ok.
*All pressures measured cold.
Daniel
That's exactly what I run mine at too. After just reading all of this thread though I am definitely going to experiment with some higher pressures starting this weekend
Link to comment
