Store Testing In Progress ×
R7 WSC's Blog
  • entries
    5
  • comments
    34
  • views
    212,059
Arduino Switch Controller - finished
Kit Car Electronics
blog-0403855001357144597.jpgWell the steering wheel transmitter and dashboard are almost finished - now I need the wireless switch controller so it all works...
Previous blog on button upgrade gave the basic details - this is a continuation.
The heart of the switch controller is an Arduino Nano micro-controller - this is going to be the interface between the dashboard switches, wireless steering wheel buttons and the car's lighting, indicators, windscreen wipers and DigiDash2 GPS stopwatch.
So far, I have got a 2.4GHz transceiver working with the Nano - receives all the steering wheel button presses:
This should make it easy to have self-cancelling indicators, intermittent wipe, auto wipe on wash, plus can use multiple button presses to choose sidelight/ headlight or wiper speeds - any logic you like, really since its all software controlled. Also removes the need for any electronic hazard flasher or ballast resistors with LED lights, as the MOSFET should handle it all.
I've started on the wiring schematic for the controller - first time I've used MOSFETS, so should be interesting - any electronics enthusiasts please feel free to critique. :) I'm using the excellent (free) expressSCH software having previously drowned in untidy paper sketches...
Next step is to mount the voltage regulator and input/ output resistors on a stripboard and get the thing cased up, then put the transistors/ MOSFETS on a large heatsink that will attach beneath the scuttle somewhere and sort out the wiring mods to the Westield loom...
Here's an updated schematic that includes the circuit for low-side switching and component part numbers: I realised that it would be easy to use low-side switching on the wiper motor as the ground is accessible - the circuit is simpler and high current N-channel MOSFET's are cheap.
I'm going to start testing the circuits and writing the code this weekend hopefully... If I find anything wrong, I'll update the schematic in case anyone else plans to use it 😉
10/1/13 - tested all the circuits - no problems found, so I went ahead with the stripboard layout, about to start soldering up...
13/1/13 - stripboard finished, ordered a box and some pcb terminals to make it easy to wire in... Getting closer!
21/7/13 Distracted myself with some building projects at home, but back on the case now...
Added the pcb terminals and fitted to a case - ready for mounting in the car finally...
Arduino sketch
29/12/13 Finally finished! I made a few changes to keep hazard and sidelight circuits working with the ignition off- the Arduino effectively just replaces the indicator switch and controls dipped and main beam relay. I also added a reed switch with single magnet on the steering column to cancel the indicators. So a single indicator press will switch on for up to 15 sec if the steering doesn't move, but if the steering returns to straight ahead then I wait 3 secs and cancel. This should work well for roundabouts or side turns. Otherwise, pressing the button again will turn off, or pressing the other side button will switch direction. It would be really easy (and cheap) to just make a self cancelling indicator controller better than any you can buy using the same method - perhaps I should draw a kit up?
Final version of schematic and stripboard layout.
I had planned to use the hazard feed with diode as shown on the schematic earlier, but in the end decided it would be easier and safer to hard wire the hazards as 'normal' but then use the normal 'Lucus switch' live indicator feed to supply the Mosfets. This means that even if the Arduino fails, the hazards still work.
For the sidelight, I've hardwired it with a latching changeover Durite relay, so it always toggles on/off/on/off/on/off with a savage momentary switch (could also have used a latching switch with a standard relay which is cheaper). Then I sense the 12V relay changeover (so HIGH when sidelights off, LOW when on) and use this to cycle headlights on and off. So with ignition off you get sidelight on/off/on/off, but with ignition on you get side+head/off/side/off/side+head/off etc. If headlights are on then main beam latches on or off with each button press, otherwise main beam is just a 1s flash. Seems to work well...
Dash nearly finished:
wiring about to be connected and tie wrapped – you can just see the reed switch inside heatshrink tied below the steering column top bracket.
Then I have a strong small magnet (8x5x2mm) attached to the shaft so the switch is closed around the straight ahead position:
MOSFET’s and wiper park relay
It’s working perfectly – takes about 2 seconds to boot from ignition on, which is fine. I’ve added all the diodes and resistors for the Savage lights so they all work nicely too.
17 Comments
Recommended Comments
I'm guessing it would be fed from a switched live. If so then you won't have any hazards unless the ignition is on. How about if you make the relay switch double gang (think that's what it's called) to provide a secondary switched live so you would always have hazards
Link to comment
Kit Car Electronics
Good point! The Savage hazard switch is a double pole latched one, so I can add a secondary live off a permanent feed like you suggest, thanks :-)
Link to comment
Kit Car Electronics
I was too busy drawing pretty pictures to think about how to fit this - of course the car wiring is all high-side switched, so I need to change the N-type MOSFETS to P-type. Version 2 on it's way...
Link to comment
adamnreeves
I acutally bought an Arduino module last year with view to doing this.
Not had much time to do much with it other than writting some programs to control LEDs etc. So I am watching with interest.
Link to comment
Kit Car Electronics
I thought there'd be some other arduino 'enthusiasts' out there, Adam! I've ordered all the parts now, version 1.2 details coming soon...
Link to comment
Dave Eastwood (Gadgetman) - Club Chairman
Await with interest!
Link to comment
Sparkymart
Just seen this blog I'm well impressed I was thinking about making steering wheel switch setup but using slip rings.I've looked at the Arduino but never done any writing of code.so will the transmitter be self powered by its own battery if it is how long would it last ? Did it cost much for the components to build it.can the Arduino drive a LCD screen be cool to have warning indicator's displayed on a screen instead of plain dash lights
Keep up the good work
Link to comment
Kit Car Electronics
More info on my other blog on the steering wheel, but basically the battery should last a few years... I haven't added it all up, but will be much less than the cost of the buttons... LCD no problem, touch screen could also be possible instead of buttons...
Link to comment
Okey Dokey Arduino kit arrived yesterday, along with some test kit stuff to have a play around with before actually attempting to make an in-car controller.
Least that way I can thoroughly test the basics of it on the bench to make sure I've got programming/wiring correct!
Link to comment
ian clear
I have found this Blog very interesting. I built myself a self cancelling indicator unit and have purchased from Rally Design a steering wheel with two buttons which operate the indicators. My SW is removable so I connect it via a 3 pin cable. I am contemplating adding a horn button and headlight button but this would make the cable rather large, so WiFi may be the way to go. I already have an Aduino as I hope to one day build a performance monitor using the signals that supply my speedo from the Lobro joints.
Link to comment
Good to see you've progressed!
interesting to see the code; just at the learning the differences stage at the moment. (Have done some work in C-like languages before, though not quite the same!)
Dave
Link to comment
Kit Car Electronics
All tested, apart from the mosfet speed control for the wiper motor, fingers crossed! Just need to make a heatsink plate now!
Link to comment
ian clear
The key to your system is your code for the Aduino. I have an Aduino Uno also a detachable steering wheel. I would be interested in seeing a copy if you are willing.
Link to comment
Kit Car Electronics
I've put the code up here as a pdf, Ian (last post in blog) - I can email you the actual Arduino sketches if you prefer - just pm me your address.
Link to comment
