cast iron
Full Load "pinking"
rebuilt last years race engine with all but the old knife edged and lightened crank, same compression rods pistons cams and head, put the original map back in and its pinking / knocking badly at full load from around 3K. Lift to part load or change down and its fine.
What can have changed to cause this?
I can only think that the standard heavier crank wont spin up as quick?
The TPS values are spot on, strobe shows the timing to be pretty good.
Share this post
Link to post
fuel or thinner head gasket maybe
Share this post
Link to post
Sounds like it's detonating.
Maybe requires a different AFR or ignition timing to stop the detonation - if you have a vacuum leak, injector gone out of spec, fuel pump/filter/regulator/different octane fuel (or older) etc all could cause it.
If you have overbored the engine this will increase compression as will a change in cam timing.(I appreciate you do say same pistons)
Spark plugs too 'hot' - have you changed plugs to a 'hotter plug'?
Anything that slows down the turning of the crank will keep cylinder pressures higher for longer and can instigate the 'second' burn.
Unless you stop it you will damage the ring lands on the pistons very quickly.
- needs a re-map urgently.
Share this post
Link to post
Hi Fraser, I know what it needs, just like to know a reason why:) Nothing changes without a reason. If I could find and fix the cause I might avoid a remap. Oh well off to the rollers with her
Share this post
Link to post
If it wasn't so wet I was going to go out and play. Will just do the geometry today. Local rollers booked for 21st :)
Share this post
Link to post
Well a turn up for the books, perhaps i didn't fully explain the situation, which doesn't help!
The car was overheating yesterday 105 degrees, this morning i bled the system cold, ran it at tick-over up to temp, bled it off again, now the temp is pretty solid at 90 degrees in all conditions and it doesn't pink!!
Still going to get it checked over on the rollers and wont be thrashing it just yet
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
