Sign in to follow this
terry everall
Favour Needed
Steve's engine refusing to start for some reason an its 3 sisters this Sat
Its definately the electrics as plugs are a bit wet.I can replace crank sensor and coil pack but do not have a throttle pot ( connects to MBE loom)
Anyone got one available that they could post to me so I can try it? Will return it asap and reimburse postage etc
Terry 07767836234
Share this post
Link to post
I also think you should check the date for 3 sisters, I was under the impression it was Sunday, not saturday.....
Also, is there a spark when cranking? If so, then the crank sensor works. If no spark, start with the crank sensor. If it sparks, and won't run, then the TPS may be a problem, but how do you intend to set this up once replaced? Does it not need software? & If you have software, use the trouble shooting to find the fault.....
Share this post
Link to post
yes i was about to say that on my dta it records fauly reading [had a dodgy crank sensor once ]and it showed over 14000rpm rev max.
which was causing engine cut out.
throttle pot may just need resetting for open /close settings
Share this post
Link to post
Paul
3 sisters is Sunday but need to sort out by Saturday
I hav not testd anything myself but Steve says it tries to fire ( even backfire) and plugs are wet
If crank sensor faulty would it fire at all?
Not sure I have full MBE software but it can bee downloaded so I hope I have a serial lead to connect to ECU
Its a major issue as I am not available until Friday!!!!!!!!!!!!!!!!!!!!!!!!
Share this post
Link to post
Tell him to get it on his trailer and take it somewhere that knows that knows what they are doing to get it sorted - chop chop!
Share this post
Link to post
Has he check everything else terry before messing with the electrics such as the actual timing or fuel pressure reg to see if it's over fueling and flooding the car.
Share this post
Link to post
fitted new plugs to get it started but within 20 scs it was ovefuelling spewing out nasty exhaust smoke
Spoke to Paul Exon who believes it could be a throttle pot issue
Going to take car to him tomorrow and hope its a simple reinstall of ecu map and check throttle pot etc
Share this post
Link to post
if pot is not reset in normal position it will over fuel
Share this post
Link to post
:t-up: :t-up: bet he was getting worried
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
