woodman
Fuel injection help please.
I am fitting a standard Toyota 20V 1600 to my old westy.
I have always had engines on carbs before so am a bit unsure of best fi pump to use .
It will be used for Hillclimbs and already has a 10L tank - redtop pump - swirlpot 11/2L
Then I think i need- Fi pump? - fine filter?-engine
just looking for a budget setup, I have seen some at 'Rally Design' but didnt really know which is most suitable
any advise please
thanks
Stu
Share this post
Link to post
It's a lengthy read, but everything you'd ever want to know about budget fuel injection conversion parts is hiding in here:
Matt Lewis Racing (mentioned in that thread) are great for Sytec pump and filter by the way
Share this post
Link to post
Thanks Mike
I will have a read thru.
The 20V engine has come with individual throttle bodies as standard, I have an omex 500 + trigger wheel.
Will the regulator be necessary between the pump and swirl pot?
thanks
Share this post
Link to post
I presume you mean the existing carb pressure regulator? In which case no, it isn't needed and you could just swap to a simple filter to keep the fuel clean entering the swirl pot from the low pressure pump
@Chris King - Webmaster and Joint North East AO has a nice swirl pot schematic that he's forgotten about recently
Share this post
Link to post
I resemble that comment!
My tank has a basic gauze filter inside (std I believe) and the lp pulp has a filter in it too. So I only have one inline filter added to keep crud getting to injectors.
Share this post
Link to post
The Sytec pump from rally design is a good shout. Both Marto and I use the 8mm feed in and out, with a fuel filter before and after the pump. You can spec them to suit the lines coming from the tank - they're fully customisable.
I tried a Bosch 044 copy item but they're crap. The Sytec one is great though.
Share this post
Link to post
Have you got a small tank you can fit and do away with the swirl pot and low pressure pump? I may have one if you don't.
Then a high pressure pump and a fuel filter from a ford or Saab. I may also have a spare pump and part number for filter.
A
Share this post
Link to post
Thanks Ash.
I have my old  foam filled 10L tank. It has an 8mm supply pipe ( to LP pump ) and also a return pipe and also a vent.
I already have a swirl pot with 8mm return, 8mm inlet, vent to fuel tank and 13mm to pump.
I thought I would use swirl pot due to only having 8mm feed to Fi pump if direct off tank- Is that right? But I would prefer just to feed the HP pump direct from tank and do away with swirl + LP pump if the 8mm feed would cope. Its only a std engine after all.
if you have a spare Pump/filter then that would be great. I had been looking at the Sytec ones from 'Matt lewis racing' as recommended in an earlier posts by Mike and Barney. ( Are you by any chance attending 'Bromyard Speed Festival' at SW or Loton next week?)
Thanks Stu
Share this post
Link to post
Hi . We are at Loton next weekend and will take parts along.
Get your tank rewelded with a bigger fuel feed line. Or if its a flat tank fit a bulkhead connector. Get to a dash 8.
Easy enough then you can delete the swirl pot, extra pump, wiring etc.
Share this post
Link to post
Thanks Ash
I hope to be there with Tim Pennington.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Please review our Terms of Use. We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
