Kit Car Electronics
HiSpec mechanical handbrake adjustment
1 hour ago, DE04* said:
Yep done exactly the same when I first got mine couldn't get them to work and just gave up on them. About 3 years ago is when I asked Hispec at Stoneleigh and they told me about it, but only took calipers off recently for the upgrade. More than happy now.
Oh well,I've only done a couple hundred miles since fitting mine,so maybe a job for next winter get them modified
Share this post
Link to post
I can confirm that a 5mm allen key does indeed fit in mine! Not had time to adjust etc. Will report back after I have.
Share this post
Link to post
Good luck to everyone with the "upgrade".  Personally I can't seeing it being of much help.  You will never get the clamping force associated with a standard rear caliper or grip with drums.
Mine works fine, but there was quite some time needed to adjust the pads correctly to the disc, and then fiddle with the cables.
Share this post
Link to post
I have discovered I'm lucky to have the magic grub so have been adjusting but not finished.
First attempt I made the pads just grip the disk then backed off half a turn. This was too tight as they bound when apply and removing the handbrake.
Then I found that adjusting the inside grub screw needs you to hold the disk firm as if the wheel was on because otherwise as you tighten the disk moves out.
Currently I've nearly finished trying a full turn but decided to call it a night.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Please review our Terms of Use. We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
