Harris built 1700 crossflow. High spec, dry sump’d
James_westy
Selling my Harris crossflow. Engine is currently in my car so can be seen running and won’t be removed until sold or at least I’ve taken a deposit.
Call this a gauging interest ad if you like but I am serious about selling but it won’t go for peanuts I’d rather keep it.
The engine has covered 1,500 road miles (this is backed up by invoice dates and Mot’s) and three Trackdays. It’s a serious engine that could be used for racing or for a fast road car.
Been dyno’d at about 160/170hp allowing for dyno differences! Very strong and pulls like a train.
Spec:
accrolite 83.5mm forged flat top pistons
forged lotus  rods
arp conrod bolts
arp flywheel bolts
arp head stud kit
vandervell could competition bearings
12:1 compression ratio
duplex vernier cam sprocket kit
kent 244 cam
h&h electronic ignition
high pressure oil pump
chambered head/ stage 3 big valve
Titan roller rocker kit
ported and matched inlet manifold
tony law manifold fabricated in situ to give exact header lengths
lightened and balanced conrods, crank, flywheel and clutch cover
double dowel flywheel
dry sump, thermostatically opening mocal cooler
The car is currently fitted with a Quaife 4 speed clubmans box with a rs2000 bellhousing. Straight cut 1,2,3 helical 4th. This can be sold with the engine as a job lot or maybe separate if engine sells first
£3750
£3150 without box
Link to comment
  • 2 weeks later...
Hi
is your engine still for sale ?
i may have an interest in the engine and box.
when was the engine built ? Are you selling it complete with all ancillaries, ready to drop in ? I do not want an engine that is too lumpy, and ideally am looking for an engine that will pull well from low revs. Does the engine pull well ? I think the cam you have is quite mild ? Are the carbs 45 webbers ?
if you could let me know the above info and any other info you have on spec / dyno, I will come back to you.
many thanks, Simon
Link to comment
