Geoff101 Posted September 12, 2017 Share Posted September 12, 2017 A complete set of standard track front wishbones. I presume these are the ones that were supplied with my SEiW but they should also fit most narrows (I used a set from a wide on mine). They are the type that uses the Maxi ball joint. They are solid, straight and sound. You will however need new bushes as the middle is missing out of one of them and the rest are probably 24 years old. Cosmetically they aren't brilliant but I've seen worse. They look to have been hand painted so would really benefit from being blasted and re-coated. That said, they look ok from a few feet away and would be fine for abusing on a track or sprint car. £100 plus delivery please. I'm heading down to the south coast for a couple of days first thing tomorrow so I can stick them in the car if you live that way, but won't be able to post until Monday otherwise. Link to comment Share on other sites More sharing options...
Geoff101 Posted September 16, 2017 Author Share Posted September 16, 2017 These are provisionally sold. Link to comment Share on other sites More sharing options...
