Terry Everall Posted June 8, 2016 Share Posted June 8, 2016 This MBE 956 ECU has just been completely checked over and new chip (EEPROM) installed etc by Ian oddie. It comes with a complete wiring harness for a vauxhall XE red top engine using throttle bodies/injectors but could be used with other engines. Reduced price if no harness required Offers around £300 to WSCC before it goes on ebay Link to comment Share on other sites More sharing options...
Terry Everall Posted June 13, 2016 Author Share Posted June 13, 2016 bttt Link to comment Share on other sites More sharing options...
linky1967 Posted June 13, 2016 Share Posted June 13, 2016 This MBE 956 ECU has just been completely checked over and new chip (EEPROM) installed etc by Ian oddie. It comes with a complete wiring harness for a vauxhall XE red top engine using throttle bodies/injectors Offers around £300 to WSCC before it goes on ebay Hi, I've got the 956 on a XE and was thinking of an upgrade to a more modern ecu. Is the new chip an upgrade or a replacement? Thanks Link to comment Share on other sites More sharing options...
Terry Everall Posted June 13, 2016 Author Share Posted June 13, 2016 I believe its a replacement and will be good for 15 years . There is not a lot wrong with the MBE 956 and many cars use them Link to comment Share on other sites More sharing options...
John Dolan - Wirral & North Wales AO Posted June 14, 2016 Share Posted June 14, 2016 Hi Terry, My XE is on twin 45's and is standard apart from fast road cams. Would the ecu be suitable? Would a new loom be required? I'm currently using an old Alpha Webcon ecu. John. Link to comment Share on other sites More sharing options...
Terry Everall Posted June 14, 2016 Author Share Posted June 14, 2016 The loom is for injection and not carbs so it won't work AFAIK Link to comment Share on other sites More sharing options...
John Loudon - Sponsorship Liaison Posted June 14, 2016 Share Posted June 14, 2016 The loom is for injection and not carbs so it won't work AFAIK I'm no expert but I would think it should work as both have a throttle pot to gauge throttle position. Carbs should just mean that the ignition only is required and the injection elements just need disabling. Very worth investigation IMO Link to comment Share on other sites More sharing options...
Terry Everall Posted June 14, 2016 Author Share Posted June 14, 2016 John Are you using coil packs and not the old dizzy set up? Link to comment Share on other sites More sharing options...
John Dolan - Wirral & North Wales AO Posted June 16, 2016 Share Posted June 16, 2016 Coil packs but no tps. Doesn't sound like it will work but thanks anyway. Link to comment Share on other sites More sharing options...
Terry Everall Posted June 24, 2016 Author Share Posted June 24, 2016 still for sale Link to comment Share on other sites More sharing options...
Terry Everall Posted July 1, 2016 Author Share Posted July 1, 2016 Reduced to £250 before going on ebay Link to comment Share on other sites More sharing options...
Terry Everall Posted July 5, 2016 Author Share Posted July 5, 2016 Sold Link to comment Share on other sites More sharing options...
