Steve (sdh2903) Posted May 5, 2016 Share Posted May 5, 2016 Right following on from trying to sell as a package I'm now splitting this little lot up. Ive struggled to price some bits so if i'm way off the mark let me know, i'm open to sensible offers. 1995 1.8 mx5 engine and 5 speed gearbox, 90k miles, new timing belt and tensioner kit, new waterpump, new exedy 3 piece clutch and release bearing, new crank seals, new sump half moon seals, new camshaft oil seals, (all receipted) Cam cover powder coated (baffle trays were removed prior to powder coating). Comes with all ancilliaries, inlet manifold, exhaust manifold (+new gaskets), airbox, maf, coils, alternator, engine mounts, most of which are still removed. Only things I havent replaced are plugs or oil filter as yet. Complete with full engine/car loom and ECU. £500. http://i547.photobucket.com/albums/hh448/sdh2903/20160413_160544.jpg Set of OZ ultraleggera alloys, 4x100 pcd ET 37 offset, MX5, renault and more fitment. Freshly powdercoated gloss black and not been used since. They are immaculate and dont come up very often, especially in this fitment, i was looking for 12 month until these came up. They will need spigot rings to suit your application and having looked today I stupidly seemed to have misplaced the centre caps . These are very light and expensive new (700 a set). £400 http://i547.photobucket.com/albums/hh448/sdh2903/20160413_160718.jpg Wilwood powerlite kit for mx5 fitment. 270mm vented, grooved and dimpled discs, coated black to protect the edges and centres, Mintex M1144 pads. Comes with all mounting brackets and hardware. £350 (+£10 p&p) http://i547.photobucket.com/albums/hh448/sdh2903/20160505_140707.jpg Brand new rear MX5 1.8 Pagid calipers (with receipt), complete with sliders/brackets/bolts, i started to paint these but for some reason didnt finish them so will need a coat of paint to finish £100 (+£10 pand p) http://i547.photobucket.com/albums/hh448/sdh2903/20160505_140253.jpg Brand new Mintex 1144 pads to suit the above rear calipers. part no MDB1893M1144, please check they suit your application. £50 http://i547.photobucket.com/albums/hh448/sdh2903/20160505_140351.jpg New MX5 1.8 rear discs, grooved and dimpled and coated black. £40 shown with calipers and pads http://i547.photobucket.com/albums/hh448/sdh2903/20160505_140501.jpg If you want the full rear setup, calipers, pads and discs. £175 Mx5 rear driveshafts. removed from 1.8 car with push in shafts, overhauled, new outer CV joints and hub nuts, all greased and new CV boots. £75 the pair. http://i547.photobucket.com/albums/hh448/sdh2903/20160413_162036.jpg MX5 front uprights, cleaned and painted new bearings and hubs, the new bearings/hubs were £100 alone. £75 the pair. MX5 rear uprights, cleaned, painted, new bearings and upper bush replaced with polybushes. £100 the pair. http://i547.photobucket.com/albums/hh448/sdh2903/20160413_161255.jpg Sytec injection fuel pump model OTP017, pre and post pump filters. £45 (+£5 p&p) http://i547.photobucket.com/albums/hh448/sdh2903/20160505_140945.jpg Mx5 1.8 prop shaft £20 http://i547.photobucket.com/albums/hh448/sdh2903/20160413_161937.jpg New in box Delphi brake tandem master cylinder, fiat uno fitment, model LM70023, complete with new pushrod and clevis £15 http://i547.photobucket.com/albums/hh448/sdh2903/20160505_142002.jpg TD04 turbo, off an impreza, good useable condition, £50 http://i547.photobucket.com/albums/hh448/sdh2903/20160413_160613.jpg Mk1 MX5 upper steering column, complete with steering lock, stalks and shroud and ign key. Has had mounting brackets welded on ready for an MNR installation, cant remember if any of the original brackets were removed, perhaps someone on here will let me know? £20 http://i547.photobucket.com/albums/hh448/sdh2903/20160413_161735.jpg Mk1 MX5 Oe master cylinder and bias valve £10 Mk1 MX5 Clutch master cyl £5 Mk1 MX5 handbrake lever £10 Im sure i will find more but thats it for now. Cheers Steve Link to comment Share on other sites More sharing options...
Steve (sdh2903) Posted May 5, 2016 Author Share Posted May 5, 2016 Forgot to mention. Same listing is over on LocostBuilders aswell. Engine is an Aug 1995 unit so easier on emissions for iva purposes. Link to comment Share on other sites More sharing options...
andyismilesaway Posted May 5, 2016 Share Posted May 5, 2016 Pm sent re wheels Link to comment Share on other sites More sharing options...
Steve (sdh2903) Posted May 5, 2016 Author Share Posted May 5, 2016 All brakes. Front hubs and turbo provisionally sold Link to comment Share on other sites More sharing options...
Steve (sdh2903) Posted May 6, 2016 Author Share Posted May 6, 2016 Column. Rear uprights. Delphi master cylinder all sold. Newbie question but how do I edit a post? Link to comment Share on other sites More sharing options...
Steve (sdh2903) Posted May 7, 2016 Author Share Posted May 7, 2016 Driveshafts and fuel pump/filters now sold. Link to comment Share on other sites More sharing options...
