chriss1455 Posted February 26, 2015 Share Posted February 26, 2015 Hi, Does anyone know what the maximum width wheels and tyres you can for on a widebody? I'm currently running 7x15 with 195/50/15 tyres but for me they don't look like they fill the rear arches enough. Was thinking of upping the rears to 8x15 with probably 225/50/15 but I'm unsure if they would fit with ease. Any advice would be appreciated Chris Quote Link to comment Share on other sites More sharing options...
Andy (Sycho) Posted February 26, 2015 Share Posted February 26, 2015 I've got 8x15 et24 on mine, fw bodywork 215 tyres but the next set will be 225. Andy Quote Link to comment Share on other sites More sharing options...
6carjon Posted February 26, 2015 Share Posted February 26, 2015 Hi Chris you can just push them out with spacers or change the offset to move them further out. If you do this then you still keep a common size of tyre which has a lot of variety for performance compounds to choose from. It will probably only take a 10mm spacer and in most cases your wheel studs will have enough thread. If you check the ET on your wheels and see if a smaller ET will push it further out to make it fill the arch. Cheers Jon Quote Link to comment Share on other sites More sharing options...
Stuart Posted February 26, 2015 Share Posted February 26, 2015 Ever aquaplaned in your Westfield? I have, big style. Last thing I would want on mine is more rubber on the road. Quote Link to comment Share on other sites More sharing options...
cjdad76 Posted February 26, 2015 Share Posted February 26, 2015 I have a wide body with 2 sets of wheels / tyres for mine: - 1 set with 195/50/15 all round, and - 2nd set with 205/50/15 front and 225/50/15 rear Both fit fine but I needed different thickness spacers to space them all correctly: - 195's take 10mm front and 5mm rear - 205's take 15mm front and 225's are 8mm rear The alloys have different offsets, but the point is, with the correct spacers, there is a fair degree of flexibility with the wide arches. Quote Link to comment Share on other sites More sharing options...
chriss1455 Posted February 26, 2015 Author Share Posted February 26, 2015 Cheers for advice regarding spacers never thought to try them, would be a much cheaper alternative offering the same desired result Quote Link to comment Share on other sites More sharing options...
Terry Everall Posted February 26, 2015 Share Posted February 26, 2015 You can probably go up to 20mm spacers if your studs are long enough and if not its cheap to install longer ones Quote Link to comment Share on other sites More sharing options...
