Early C20XE Block
the stoat
All blocks will take either type of belt set up.
The later blocks are generally considered to be stronger but I've never been able to tell the difference TBH.
Good luck with finding a good standard bore :).
Link to comment
That is great news as I have a later block in the garage, but had been informed that I could not use my early belt and pulley set up.
I hope it is the standard bore as my pistons are 86.5 so only scope for one rebore without new pistons.
Link to comment
Yeah all you need to do is undo the dreaded e20 crank bolt and swap the bits over.
Link to comment
