pistonbroke 2 Posted August 26, 2014 Share Posted August 26, 2014 I have regcure pro stuck on my p.c. It pops up on every startup and is annoying. Anyone know how to get rid of this pest please Peter Quote Link to comment Share on other sites More sharing options...
Dibby Posted August 26, 2014 Share Posted August 26, 2014 Uninstall it? Quote Link to comment Share on other sites More sharing options...
peterg Posted August 26, 2014 Share Posted August 26, 2014 Uninstall it? ^ this, and if you can't do it under Windows then download and install CCleaner and use that to uninstall it and clean up any other rubbish on your PC Quote Link to comment Share on other sites More sharing options...
Lyonspride Posted August 26, 2014 Share Posted August 26, 2014 Failing the uninstall option, check for an entry in your "startup" folder, delete if found, should stop it pestering you at startup. Failing the above it's registry editing time (but I can guide you through that). Quote Link to comment Share on other sites More sharing options...
dombanks Posted August 26, 2014 Share Posted August 26, 2014 use cclean to have a go at it, even i can get it right with that so it must be easy and a good program Quote Link to comment Share on other sites More sharing options...
pistonbroke 2 Posted August 27, 2014 Author Share Posted August 27, 2014 C cleaner did the trick . Thanks Folks Quote Link to comment Share on other sites More sharing options...
